2.199742 controller never released inhibit bit(s)
hello,
I wouldn't want to disturb,
but here is my case
I used Raspberry pi 4B with EEPROM update to 2022.
i keep getting this message and nothing happens
I unplugged each usb one after the other, but still the same message:
I use rpi imager to install mobros
on a usb key and Bout with it, but nothing to do
he stay blocked.
while all the other os  work.
Hi @sebastien67530
do I get that correctly that you're flashing the image onto a USB flash drive and are trying to boot from there?
because I've never tested this use case at all.
all the installations we've done so far are booting from a micro sd card
so this might just not work at the moment
is there any particular reason you want to boot from a flash drive instead of a sd card?
You have to modify /etc/fstab and /boot/cmdline.txt and modify the devices listed.  It is set to using the sdcard hardware instead of USB.  My device I changed mmcblk0p1 to sda1.  Do the same for the rest.
